Flywheel Part Number 4.7l
Old Feb 21, 2017 | 09:19 PM
ra604's Avatar
ra604
Default Flywheel Part Number 4.7l
This should be a simple answer yet, I can't find a definitive one. What flywheel does a 2000 4.7L Dakota with NV3500 use?? Every parts website I've looked at either does not show one or shows flywheel shims (Rock auto). As I haven't ripped into it yet, what flywheel does this model have!
Old Feb 21, 2017 | 11:44 PM
98DAKAZ's Avatar
98DAKAZ
http://www.partsgeek.com/mmparts/fly...ge/dakota.html
http://www.ebay.com/itm/Clutch-Flywh...RYmBRw&vxp=mtr
I would call to be sure its the correct part for your 2000 as all these say 2001 I checked on a dealer web it says no longer available thats not a good thing.
Old Feb 22, 2017 | 12:41 AM
ra604's Avatar
ra604
Yes, same thing I have encountered. It looks as though the the 2001 flywheel is the same. Although rock auto shows the clutch for the same trans as being 11 7/8 for 2000 and 12" for 2001. However, I imagine that if I ordered both a clutch kit and flywheel from 2001 they would work together.... Might have to wait until I get in there to take a look.. Unless someone else has encountered this.
Old Feb 22, 2017 | 04:32 AM
98DAKAZ's Avatar
98DAKAZ
Be cautious I dont know the particulars but they made changes from 2000 to 2001 regarding the tone ring on the flywheel in regards to engine timing.
00DakDan knows this stuff wait for his answer
Old Feb 22, 2017 | 11:40 AM
ra604's Avatar
ra604
Hmm interesting. Well good advice thanks. I'll wait before I order anything
Old Feb 22, 2017 | 05:53 PM
98DAKAZ's Avatar
98DAKAZ
interesting I looked on carpart.com for a used 2000 4.7 manual flywheel and they listed some 2002 and up years and they usually know what year parts cross reference that can be used or interchangeable with each other.
http://www.car-part.com
Old Feb 22, 2017 | 06:19 PM
ra604's Avatar
ra604
Yeah I too noticed that. I'm a bit skeptical
Old Feb 22, 2017 | 07:30 PM
magnethead's Avatar
magnethead
your nearest friendly dealer should have an interchange manual.
Old Feb 22, 2017 | 08:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
The tone rings on the 4.7 are internal so no problem with the flywheel.
I got my clutch parts from the dealer. Figured the first one lasted so why not another. Besides, they go by VIN so I know they fit.
Old Feb 22, 2017 | 09:44 PM
98DAKAZ's Avatar
98DAKAZ
00DakDan usually has the correct answer
But why all these parts suppliers only list 2001 and up is weird even on ebay all 4.7 flywheels list 2001 and up you try the compatibility checker for a 2000 and it tells you no will not work on a 2000.
But I have run into this many times with my 2.5 engine they list it the part compatible for a jeep but not the Dodge Dakota 2.5. The engines are the same their are small differences but the same engine. you must have the same years 97 to 2002 that is what you need to be careful with the year is the deciding factor.
