45 rfe
Old Mar 2, 2017 | 06:51 PM
Michel111's Avatar
Michel111
Default 45 rfe
What problems occur when flat filter seal is improperly seated?
Old Mar 6, 2017 | 03:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
Air can get into the system and cause no shift or poor quality shifting.
Old Mar 7, 2017 | 12:28 PM
Parker84's Avatar
Parker84
Damn... I just posted about this... I guess I messed up the filters and seal?
Is there a magic way to put that little seal in before the twist on? I thought everything seated flat.
Is there anything to be weary of with regards to the other filter thats installed with a bolt?
Old Mar 9, 2017 | 09:28 AM
Michel111's Avatar
Michel111
The flat filter is the one that installs with the bolt. It has a seal that presses into the valve body. I don't think I recieved a new seal with my filter and thus did not remove the old seal, Mine however started acting up 2 months after filter and fluid change, trying to figure out why. Thanks for your input, 00DakDan. I think my problem is electrical, the solenoid pac, but, it only happens about twice a month in the mornings.
