Transmission interchange
Old Sep 20, 2024 | 10:07 AM
  #121
ARob97's Avatar
ARob97
Default Transmission compatibility
Originally Posted by 97ramrod1500
Yes, direct swap.
Hello,
I was wondering if a 99 Dodge Ram 1500 5.2L 2wd was a direct swap with a transmission from a 2000 Dodge Ram 1500 5.2L 2wd
Old Sep 20, 2024 | 10:28 AM
  #122
Originally Posted by ARob97
Hello,
No. Electronics are different. You can swap electronics......
Old Sep 20, 2024 | 10:30 AM
  #123
ARob97's Avatar
ARob97
Can you specify which electronics would be needed to be swapped?
Old Sep 20, 2024 | 10:33 AM
  #124
NSS, if the 2000 has the five pin, governor pressure sensor, and solenoid, and likely need to change the O/D and TCC solenoids as well, to get the right connectors for the others. You will also need the retainer for the governor stuff from the original trans. That changed too.
Old Sep 20, 2024 | 10:35 AM
  #125
ARob97's Avatar
ARob97
Sounds good, thank you for the info
