2003 pcm
Old Apr 18, 2017 | 03:30 PM
radtech's Avatar
radtech
Default 2003 pcm
I have an issue in my 03 Dakota where the voltage gauge will peg as an overcharge. I put in a new alternator which I later found out that it doesn't have a built in regulator. I was told this is controlled by the pcm. The voltage spikes are ramdom and only go on for a few minutes then go back to normal. Want to replace pcm but I am hearing stories that I have to find one from an 03 only with the same options. Are they all different or is there some interchanges possible. I found one from an 01 that have the same 3 connections. Would like for this problem to go away. Please help!!!
Old Apr 18, 2017 | 03:49 PM
Try this place. They are a forum sponsor.
http://carcomputerexchange.com/dodge...DodgeForum.com
Old Apr 23, 2017 | 11:27 AM
radtech's Avatar
radtech
went to the website and looked at the computers. my truck has the 3.9. for the 03 they only showed 1 which was for the 5.9 and has 4 plug-ins. mine only has 3 plug-ins. what other years of ecm will work with my truck?
Old Apr 23, 2017 | 03:59 PM
magnethead's Avatar
magnethead
03 would be 3.7 OHV i think, not 3.9 pushrod motor. But i could be wrong.
