Looking at a 2004 Dodge Dakota SLT Quad Cab 4WD
Old May 7, 2017 | 12:57 AM
Joe Herrera's Avatar
Joe Herrera
Default Looking at a 2004 Dodge Dakota SLT Quad Cab 4WD
Hi All
Looking for a P/U and need for a tow vehcile for my 3,500 lbs camper looking at a 2004 Dodge Dakota SLT Quad Cab 4WD with 122,434 miles..
Are these good dependable trucks?
Towing?
Thanks
Old May 7, 2017 | 08:58 AM
Dodgevity's Avatar
Dodgevity
Yes, they are reliable trucks and it will tow that weight without any issue. Of course, like with any other used vehicle, prior maintenance is the biggest factor. Since you're buying an SLT, it should have a tow package, which means it has a tranny cooler up front. Should also have disc brakes all around and the 545RFE tranny is very reliable. There will also be a connection for trailer brake module, under the dash. The 4.7L does not take well to overheating, so be sure to pay attention to any coolant leaks, fan issues, etc. Be sure to change the diff fluid and the ATF.
I'm at 274K on mine and it's my daily driver. Almost feels like Japanese car reliability, but Dodge gas mileage.
Old May 7, 2017 | 10:57 AM
Joe Herrera
Thanks for the info... What is the tow rating?
I am also looking at a 2007 Dodge Dakota SLT Quad Cab 4WD with 99,072 miles
Joe
Old May 7, 2017 | 11:51 AM
Dodgevity's Avatar
Dodgevity
Joe
It tops out at around 6,200 lbs. I'v e towed cars on 4 wheel trailers with no issue. Don't know much about the 07.
Old May 7, 2017 | 02:39 PM
Joe Herrera
Thanks - I briefly stop at the dealership just to see if they were on the lot which they were.
The 04 looked like it was better taken care of then the 07..
Old May 7, 2017 | 11:11 PM
Joe Herrera
I have a 01 Durango with 144135 miles. I had it for 4 months now but I prefer to have a P/U plus a 04 or 07 will work.
Old May 8, 2017 | 08:47 PM
Joe Herrera
Going to test drive the 2004 Dodge Dakota SLT Quad Cab 4WD On Tuesday. If it works out I will trade. Its a one owner.
Old May 9, 2017 | 07:06 AM
Dodgevity's Avatar
Dodgevity
You will really love the utility of the quad cab. Once you flip up the rear seats, you have loads of interior room, along with the bed of the truck. Makes it a very versatile vehicle indeed. I personally never cared for the looks of the 07. IMHO, Dodge knew it was going to shelve the Dakota and the design showed it. Good luck with the test drive. Bring a large piece of cardboard and run one side of the truck up on a high curb. Get under it with a strong light and check for leaks! Gas it hard in place and look for any smoke coming out of the exhaust. Tranny should shift almost imperceptibly. Also bring along an OBDII code reader and check it for any codes. People will hide things and the last you want, is something like a catalytic converter code popping after you've signed on the bottom line.
Old May 9, 2017 | 11:48 PM
Joe Herrera
Well I traded in my 01 durango for the Dakota.... Test drive went great and no leaks.... One owner vehicle and they keep it clean.... Now to learn..... Where is the Jack?
I might need to get a spare key does the key have a chip?
Its silver in color and rights like my Kia Sorento nice and smooth.
Old May 10, 2017 | 12:02 AM
Joe Herrera
File Type: jpg
