Engine swap?
Old 08-08-2017, 11:32 PM
tonypilot7's Avatar
tonypilot7
tonypilot7 is offline
Originally Posted by fortune730
I am however open to advice and input. Let me know your thoughts.
Well, it's your call, but if it were me, I would want to know for sure what was causing the problem, then make the call based on price and time.
If you are positive it's the head gasket, then compare costs in both time and money for each option. Go with the cheaper of the two.
If you can get an engine with better miles for cheaper or even money, then do the swap.
Or you could go crazy and swap in a 5.7 HEMI
If you aren't sure about the head gasket, it's worth it to do a full diagnosis.. Compression test, coolant leak test, etc. There are a lot of things that can cause a rough running engine.
Old 08-09-2017, 01:46 PM
fortune730's Avatar
fortune730
fortune730 is offline
Here is the compression info. Any ideas? REAR = Firewall
FRONT = Headlights/Grille
Old 08-09-2017, 01:54 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,274 Likes on 3,021 Posts
Whoa. That's bad...... Pull the heads, and see what ya got?
Old 08-09-2017, 03:00 PM
tonypilot7's Avatar
tonypilot7
Yeah, that's no bueno.. Pull valve covers and if the valvetrain looks ok, I would say that confirms bad head gaskets or toasted valves
Old 08-10-2017, 02:59 PM
tonypilot7's Avatar
tonypilot7
The reason I recommend pulling valve covers is to check the rockers.. The 3.7 and 4.7 for some reason like to toss them. If the intake valves on those two cyls. aren't opening, you could get a no compression reading. Here is a vid:
