Engine swap?
Old Aug 8, 2017 | 06:07 PM
fortune730's Avatar
fortune730
Default Engine swap?
Anybody have any write-ups on swapping a 3.7 out of a 2004 Dodge Dakota? I have a very rough running truck my hunch is its a head gasket. Im prepping myself for an engine swap. I want to swap it out with another 3.7L engine. Any advice as far as years to consider?
thanks
Old Aug 8, 2017 | 06:08 PM
Use the search function. Plenty of threads on the subject.
Old Aug 8, 2017 | 06:25 PM
fortune730's Avatar
fortune730
I see nothing about the question that i posted. Thanks
Old Aug 8, 2017 | 07:30 PM
2004 with a 3.7? Did you get some strange hybrid? 04 should have the 3.9 magnum????
Old Aug 8, 2017 | 08:48 PM
fortune730's Avatar
fortune730
Old Aug 8, 2017 | 08:56 PM
Interesting..... What transmission is behind it?
Old Aug 8, 2017 | 09:48 PM
fortune730's Avatar
fortune730
No clue just got it rebuilt. How would I find out?
Old Aug 8, 2017 | 10:46 PM
tonypilot7's Avatar
tonypilot7
The 3.7's were introduced in 2004. Last year for the 3.9's was 2003.
To the OP: why not just do a top end rebuild? Are you doing the work yourself or having a shop do it? Also, what are the symptoms you are having? It could be something simple that is causing the problem.
Old Aug 8, 2017 | 11:11 PM
fortune730's Avatar
fortune730
I totally agree. I am going back and forth with rebuild. Might not be that much more $ to swap it though. Also could be something simple don't know yet. I'm going with my gut feeling on this. Been around this truck long enough. Engine would need to be pulled anyway for oil pan gasket. I would do the work and swapping is almost easier.
Old Aug 8, 2017 | 11:12 PM
fortune730's Avatar
fortune730
I am however open to advice and input. Let me know your thoughts.
Originally Posted by fortune730
I totally agree. I am going back and forth with rebuild. Might not be that much more $ to swap it though. Engine would need to be pulled anyway for oil pan gasket. I would do the work and swapping is almost easier.
