Engine 1 fuse keeps blowing.
Old Aug 11, 2017 | 04:22 PM
  #31
Clueless22's Avatar
Clueless22
It looks the same.Hopefully it's just the 4 small head bolts not having enough threadlocker.
Old Aug 11, 2017 | 05:26 PM
  #32
Wouldn't hold my breath on that....
Goop the bolts, pressure test the cooling system.
Old Aug 11, 2017 | 07:28 PM
  #33
Clueless22's Avatar
Clueless22
Can you rent the testers?
Old Aug 11, 2017 | 09:35 PM
  #34
Yeah, parts store should have 'em.
Old Aug 15, 2017 | 11:00 AM
  #35
Clueless22's Avatar
Clueless22
Timing was off a tooth.Checked the heads while I was at it just the head bolts. None of them have the same torque some at 90 some at 95 shouldn't they be tighter?
Old Aug 15, 2017 | 12:47 PM
  #36
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
They might differ depending on length, girth, etc
There's really no way to tell if they were torqued correctly, UNLESS you loosen them and go back through the torque sequence. Loosen THEN torque ONE AT A TIME on first step....IF you decide to do anything.
Rechecking all wires now.New crank and cam sensors.Has to be something simple I'm overlooking.
NEW as in Mopar or cheap crap from Autozone?
