alarm
Old Oct 11, 2017 | 04:56 PM
02rtowner's Avatar
02rtowner
Default alarm
My doors lock and unlock on their own. I do not have a remote key or keyless entry. I have to unlock hatch then front door to get inside without alarm going off. Most of the time it works, other times the alarm goes off anyway and I have to crank it for it to turn off. It's an 02 durango r/t
Old Oct 11, 2017 | 07:07 PM
Skreelink's Avatar
Skreelink
You may have a keyless entry system, especially if you have an alarm. Find a cheap dodge keyfob on ebay and follow the programming procedure to see if you can pair it with your durango. You might just have found a feature you didn't know you had.
Old Oct 12, 2017 | 06:58 PM
02rtowner's Avatar
02rtowner
Default Alarm
Thank you! I will try that
Old Oct 13, 2017 | 08:25 PM
00DakDan's Avatar
00DakDan
Section Moderator
You won't be able to "pair" it without a working remote. The dealer can.
Old Oct 13, 2017 | 08:34 PM
Skreelink's Avatar
Skreelink
https://itstillruns.com/program-keyl...b-6194237.html Grounding pin 1 to 4 bypasses the dealer.
