Code p0306
Old Dec 30, 2017 | 11:45 AM
magnethead's Avatar
magnethead
sensor was $115 at dealer. Can't get to it from below. Two 1/2" bolts behind passenger cylinder head, connector is behind the distributor.
Old Dec 30, 2017 | 11:59 AM
hidden1's Avatar
hidden1
Thanks.anything else I should get for it at junkyard?
Old Dec 30, 2017 | 02:02 PM
magnethead's Avatar
magnethead
Yours is an automatic, right? The manual ones are different and a PITA to find, I don't think the dealers even stock them. 3.9/5.2/5.9 auto all use same sensor. I think 3.9/5.2 manual are both the same but not 100% sure on that.
Old Dec 30, 2017 | 02:37 PM
hidden1's Avatar
hidden1
3.9 ,6 cyl,automatic.
I'll get a injector while I'm there..can a cam sensor effect this ?
Old Dec 30, 2017 | 03:35 PM
magnethead's Avatar
magnethead
A bad cam sensor would be giving a bunch of random misfires, not one specific cylinder or a bank. Grabbing an injector or 2 wouldn't hurt, but make sure they are the came color and connector as yours - they switched from EV1 to EV2 at some point.
Old Dec 30, 2017 | 08:37 PM
hidden1's Avatar
hidden1
What is Ev1/2?
What is odd is it's running like nothing's wrong ,plenty of power an no misfires..
Old Dec 30, 2017 | 10:09 PM
They changed the design of the connectors for the injectors at some point. The EV2 are the newer style.
Old Dec 31, 2017 | 04:27 PM
magnethead's Avatar
magnethead
What is Ev1/2?
This is why I am leaning to crank position sensor. The PCM is firing the coil and injectors at the right times, but is registering a double hole as a single hole. This throws off it's internal clock keeper.
