Power locks and windows
Old Apr 27, 2018 | 08:19 AM
dodgedakotaslt's Avatar
dodgedakotaslt
Default Power locks and windows
Hello there guys i some help with wat would i need to fix my power locks and windows. I cant lock my doors and i can only roll down the window using the master switch on the driver door. I think its the fuse box under the dash but want some input first because we all know that fuse box is a pain to get to and when i try to lock the doors i can hear the switch trying to lock the doors.
Old Apr 27, 2018 | 08:57 AM
00DakDan's Avatar
00DakDan
Section Moderator
What year is your truck? What body style?
The power window master switch issue is pretty common. You can jump it.
If you hear the power locks trying to work then the actuators are likely bad, or gummed up.
Old Apr 27, 2018 | 09:59 AM
dodgedakotaslt
Its a 2002 dakota slt 4x4 with the 4.7
Old Apr 27, 2018 | 10:14 AM
dodgedakotaslt
Would my actuators from my 2000 dakota work on my 02 and if it makes a difference my 00 is a 2wd and my 02 is 4wd
Old Apr 27, 2018 | 01:12 PM
00DakDan's Avatar
00DakDan
Section Moderator
2 or 4wd does not matter. 2 or 4 DOORS does.
The actuator should work.
Old Apr 28, 2018 | 07:34 PM
dodgedakotaslt
Well its not the actuator, i switched out the one from my other dakota but like i said it i tried to roll down the window and lock the door and the window wont go down nor will the doors lock. All i can hear is the switch trying to do wat i want done
Old Apr 28, 2018 | 09:25 PM
00DakDan's Avatar
00DakDan
Section Moderator
When you say "actuator" do you mean the door lock itself or the switch panel?
Old Apr 29, 2018 | 07:31 AM
dodgedakotaslt
The door lock
Old Apr 29, 2018 | 08:34 AM
Getting power to the switches?
Old Apr 29, 2018 | 08:53 AM
00DakDan's Avatar
00DakDan
Section Moderator
The locks and windows are two different systems but do share a common ground. G307, it's located on the driver door pillar, just above the floor. If you follow the wiring for the seatbelt switch it'll be right there.
Does your power mirror work? It's on the same ground.
