97 Dodge Dakota need new rear end 3.92
97 dodge Dakota cant find the 3.92 rear end anywhere or the gear that is what is ruined. Parts store doesnt even sell that gear. Its so weird can find the 3.5 but not 3.9 I live in Georgia, anyone got one for sale around Georgia. Thks
3.92 gear should be easy to get from the aftermarket- stick to Just Differentials (Nitro Gear) or Yukon Gear. Do you have the 8.25" or 9.25" rear axle?
8.25" is oval cover, 9.25" is hexagonal cover.
Sorry this doesn't have much to do with your post but maybe you can help me. I am wondering where you might find the gear ratio other than a tab on the differential bolts? Just blew out my ring and pinion gears. Found a small tab with 3 9 and then another tab with some numbers that was so rusted I cant even make it out. Would you guess that would make mine a 3.92? I don't mean to bother but I am pretty new to all of this. Thank you for any help you may be able to provide.
Sometimes it will be on the option sticker. The ring gear does have the numbers stamped in most cases. If not, you can mark one tooth then count them by rotating the gear.
Last edited by ol' grouch; Nov 13, 2020 at 08:34 AM. Reason: i kant spel wurth a durn
Trending Topics
There are plenty listed near in GA. Not sure where you are or 2 or 4wd.
Other years will also fit, as will the 8 1/4 or 9 1/4" but you may need to change your driveshaft. Any good boneyard will have an interchange manual.
Try this link: Car-Part.com
