No AC, Clutch Doesn't Kick On / Engage!
Old 06-26-2018 | 07:26 AM
So long as the pressure on whatever side is lower than pressure in the can, sure, it'll flow in there. I think having both valves open at the same time though, will tend to have the system use the gauge set to equalize pressures....... just doesn't seem like a good idea to me.
  #22
Old 06-26-2018 | 11:28 AM
98DAKAZ's Avatar
98DAKAZ
Lightbulb
Not sure what to tell ya A/C work can be a tricky thing especially if you dont know why it was disconnected by the last owner.
A part may be plugged like the orifice tube or condenser it took me 3 trys before I fixed all the problems my A/C had.
My system had black death and was fixed by a shop but they never cleaned the system or replaced everything needed. This was 4 years before I started refurbishing the A/C myself. I missed a few things that forced me to fix it two more times so replacing as much as possible is a smart move.
The shop that fixed the black death never told me that was my problem and why it died. When I opened it up the first time the orifice tube was black and mucked up. Second time I fixed it the schrader valves were leaking when I looked at them they were toast the black death had cooked them.
  #23
Old 06-26-2018 | 12:45 PM
magnethead's Avatar
magnethead
Yep, mine failed due to a blocked oriface valve that wiped out the compressor.
  #24
Old 06-26-2018 | 01:06 PM
972ndGenSLT's Avatar
972ndGenSLT
So, this morning I went back to the drawing board. With the gauges reading 0psi, I pulled the 10mm bolt and removed the lines, inspected the flat o-ring washer things, made sure everything was seated nicely and reinstalled the 10mm bolt. I then hooked up my gauge set and vacuum and let it run for about 15-20 minutes per the manual then closed off the valves. Gave it about another 15 minutes... lost some vacuum pressure. Repeated what I did above, with one addition. I added a little thread seal tape to the end of the 10mm bolt. Back to vacuuming it down for about 20-25 minutes and letting it sit. This time I found a can of r134a w/ the UV Dye that had about 15% in the can. It has the push button top so I was able to force some in. Switched to another can and about 10% went in and then all suction stopped. When I connected my gauge set my lowside was at 40psi-50psi and highside was around 30psi. At what pint does the LPS kick in to allow the compressor to run? I'm also not hearing an audible "CLICK" when I jump the compressor with the battery. I can only see this ring being drawn forward as if towards a magnet but no clicks, no turning of the clutch assembly. Would we say this is yet another bad compressor?
  #25
Old 06-26-2018 | 01:14 PM
magnethead's Avatar
magnethead
why are you using junkyard compressors instead of just buying a new, known good sanden? You have no idea if junkyard ones are good, they could be rusted out inside.
  #26
Old 06-26-2018 | 01:34 PM
972ndGenSLT
I'm beginning to ask myself that question, but when the local yard had a 50% off sale I got the a/c compressor for about $35 which included a 12 Month warranty... The new one you mention is at least $100. At this point my effort and trips back and forth have already exceeded the $65 difference.... But I want that sense of accomplishment.
  #27
Old 06-26-2018 | 01:43 PM
98DAKAZ's Avatar
98DAKAZ
Question
I agree sandens are the best but pricey other brands are cheaper but not sure of the quality.
But yea why junkyard compressors?
  #28
Old 06-26-2018 | 01:49 PM
98DAKAZ's Avatar
98DAKAZ
I forgot but a high side of 30 psi is way low almost impossible you must mean 300 psi.
  #29
Old 06-26-2018 | 02:08 PM
972ndGenSLT
98DAKAZ,
Why Junkyard Compressors... because the local yard had a 50% off sale I got the a/c compressor for about $35 which included a 12 Month warranty... As to the highside psi, you read it correctly...30ish....it may have reached 40psi.
  #30
Old 06-26-2018 | 02:19 PM
98DAKAZ's Avatar
98DAKAZ
Take a closer look at your gauge most show in 3 or 4 pressure scales you must be looking at the wrong one.
Its impossible to have a lower (high side psi) than the (low side).
Well I guess if the compressor is not pumping then both high and low side would be equal but I dont see that happening it should read very low about 15 or 20 psi.
Quick Reply: No AC, Clutch Doesn't Kick On / Engage!
