1997 dakota starting issues
Old Aug 20, 2018 | 01:12 PM
Gliderdad's Avatar
Gliderdad
Default 1997 dakota starting issues
i have a 97 dakota 4wd,5.2,5spd with a mild 144k on it.
Recently it takes several turns of the key on and off to start. Once started...runs great. If I flip the fuel pump relay with another..it will fire right up...then the next time I go to start the truck it may fire right up..or we do the key thing again. It is very sporadic.
about a year ago I swapped the keg for a Hughes manifold, added k&n cold air,headers,magnaflow and Gibson exhaust,plugs,wires,high amp alternator,180 degree thermostat,fuel pump,and coil.
any feedback is greatly appreciated.
Old Aug 20, 2018 | 09:06 PM
Test fuel pressure. Trouble is, I think the 97 magnum engines was the ONLY year for the plastic fuel rails, that did NOT have the pressure test port.... so, gonna have to get creative.
Old Aug 25, 2018 | 08:14 AM
Gliderdad's Avatar
Gliderdad
Haven’t had the chance to figure a way to test fuel pressure yet.
i did realize that this is somehow related to outside temperatures. We had a couple cool days ..70 to 80 degrees.. and it fired right up with no issues. Once it got into the high 80’s and 90’s I had to do the relay swap thing again.
is there such a thing as vapor locking in a fuel injection system?
Old Aug 25, 2018 | 08:16 AM
Not at those temps. If the engine were hot, maybe......
Old Aug 26, 2018 | 02:25 AM
Fezman's Avatar
Fezman
Probably a fuel pump ready to take a crap, or, the wiring going to the pump, when you turn the key on you should be able to hear the pump
Old Sep 2, 2018 | 06:33 PM
Gliderdad's Avatar
Gliderdad
Ok...I am not understanding how it could be the fuel pump when,once started, it runs great. Will figure a way in the morning to check fuel pressure. I checked wiring for problems and found nothing. The fuel pump kicks on every time I turn the key and the relays are kicking in as well.
Old Sep 2, 2018 | 07:53 PM
magnethead's Avatar
magnethead
just because you can hear the pump, does not mean it is pumping. More specifically, the louder the pump is, the less likely it is pumping.
Old Sep 3, 2018 | 12:40 PM
Dodgevity's Avatar
Dodgevity
How are the plugs? Also, are you losing a bit of coolant now and then? My 4.7L did that when it developed a slight head gasket leak years ago. Pulled the plugs and #5 was super clean (steam cleaned) with perfect gap. The rest were worn as they were supposed to be at that point with over 30K on em. Never felt any loss of power or stumbling, but it went from firing immediately to a 2 sec crank as first indication of a problem.
Old Sep 3, 2018 | 05:53 PM
Gliderdad's Avatar
Gliderdad
Fuel pressure is good, plugs are good.
now when I do the relay swap thing it fires up..hits about 1100 rpm..stumbles sputters and dies.
Won,t start back up now.
Brain?
