Climate control
Old Sep 3, 2018 | 11:30 PM
PjonesIII's Avatar
PjonesIII
Default Climate control
My 1999 Dodge Dakota Sport has no climate control unless you move the AC compressor relay and the blower motor relay and you jump them can someone tell me how to correct that
Old Sep 4, 2018 | 06:49 AM
You have two separate problems.
For the a/c compressor, I would be you are simply low on charge.
For the blower motor, need to find out where you are losing power.
Old Sep 4, 2018 | 10:09 AM
00DakDan's Avatar
00DakDan
Section Moderator
There should be a 10 amp fuse in the junction block, under the dash, for the HVAC relay and compressor clutch relay.
Old Sep 4, 2018 | 12:10 PM
PjonesIII's Avatar
PjonesIII
Where under the dash is it located
Old Sep 4, 2018 | 12:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
Side of the dash. Open the door and you should see the cover to the panel.
