This Old Hub question. Timken vs SKF
Ok ive been trying to research these two hub assemblies but i am constantly getting conflicting specs and info.
Do both Timken and SKF use tapered roller bearings or ball bearings? One website will say one thing and another website will say the other.
Additional questions
Does Timken still use a poly cage??
Has anyone ever removed the seal and repacked a bran new hub?
Does packing the bearing with a needle grease fitting make the seal useless?
And finally
Is buying a MOPAR hub assembly worth the double cost? Will i get twice the life compared to after market hubs?
(On a side note:
I recently read a post from a endurance racer who felt that the after market hub bearings did not come with enough grease packing and his personal experience was that he would get more laps when he would repack the new bearings before installing them. )
Additional info: factory hubs were changed at 124k with nonames. 10k miles later nonames are failing.
And finally
(On a side note:
My understanding is that SKF, is or was, the OEM supplier back when.
I wouldn't bother trying to grease a sealed bearing. You really can't do it properly with a needle and can damage the seals. It's not just a matter of injecting grease. You also need to make sure whatever grease you use is compatible with what is already in the bearing.
How long did your current bearing last???
Im going to assume this is for a 2nd gen Dakota
Both Timken and SKF are what you want but a no name will work I guess it depends on your environment. I have 1 Timken and 1 no name I have no problems with either but I live in Arizona the cheap hubs may not like the rust belt zone. These hubs all of them are sealed units no lubrication can be applied.
