Grinding when turning left
Old Feb 15, 2019 | 02:26 PM
  #51
magnethead's Avatar
magnethead
Just a cautionary note...If it was out-of-line with the trans mount MIA, then you might want to take a peek at those engine mounts too... IJS
Old Feb 15, 2019 | 05:17 PM
  #52
Skreelink's Avatar
Skreelink
Glanced at what I could of the passenger mount, it looked fine. Rubber was smooth and no cracks, but didn't get to really inspect it, I'll have to get my endoscope to actually get into engine bay to look at it. Didn't get a look at the driver side, too much stuff in the way. Maybe I'll get lucky and when the previous owners put an engine in, they dropped new motor mounts as well.
Otherwise, it SEEMS to have been the problem. The cheapest/relatively easiest solution was the fix. Did a test drive during break at work, doing some hard lefts, then all the way home with no vibration/noise. I do wish I would have gotten a good recording to help others identify if it happens to them. Ah well, I'm sure my truck appreciates everything I've done.
Log of the Adventure:
Parts changed:
1: Front Wheel Hubs L/R - Timkins
2: Front Rotors L/R - Nakamoto
3: Front Brake Pads - Wearever Gold
4: Rear Brake Kit - Carlson
5: Rear Brake Shoes - Wearever Gold
6: Rear Axle Bearings L/R - SKF
7: Rear Diff 75W-90 Full Synthetic Oil Change
8: Front Shock Absorbers L/R - KYB
9: Transmission Mount (SOLUTION) - SKP
ToDo:
1: Rear Shocks
2: Check Motor Mounts
3: Rear Brake Drums
4: Bump stops
Anyone have a picture and possibly part number for the rear bump stops on a RWD? My truck appears to have none on the frame rail, and I'm missing the passenger side on the front. I've found Mopar replacements for the fronts, but I want to doublecheck the back before buying any. After this list is complete, my suspension an driveline should be pretty much a-ok.
