ABS/BRAKE, check engine, no speedo or trip, air bag on
02 dakota 3.9l v6 4x4. The truck doesn't want to shift at right rpms in first and 2nd. Also dies sometimes when letting off gas coming to a stop. I pulled the codes P0500. I have also replaced the rear wheel abs sensor, PCM, head light switch and ignition switch. I haven't replaced RWAL because it tested good. Anyone else having this problem and has fixed it? I found a harness connection in driver inner wheel well that looked wet. Idk if this could cause problem. Running out of ideas and money
P0500 is vehicle speed sensor, it should be on the transmission. It reads how fast the transmission is turning to know when to shift, requires I *think* a 1 1/8" deep well socket to remove (may just be a 1" been awhile since I swapped this). The ABS sensor (ontop of the rear diff) controls the speedo up to about 35mph and the ABS. If it's dead, the ABS/Brake lights come on and speedo won't work until ~35mph. Letting off the gas and dying sounds like the IAC, it's on the back of the throttle body under the air hat. You can clean it and the passage, but be gentle and do not move the plunger while it's out.
Breakdown in order:
1: Remove airhat and throttle body: Clean throttle body, IAC port, and IAC. This /should/ fix your stall when stopping, if not, try replacing the IAC. (it controls air flow for idle, if it sticks closed, when you let go of the throttle, it chokes the engine)
2: Replace speed sensor on the transmission, should fix your shifting and P0500 code.
3: If shifting is still erratic, check TV Cable tension, replace TPS.
Recommended that you grab some CRC contact cleaner and clean every harness on these sensors and use dielectric grease to prevent corrosion.
Breakdown in order:
