need help asap, 4.7 wont go over 3000 rpm
Old 02-07-2019, 09:37 AM
Skreelink's Avatar
Skreelink
Skreelink is offline
There are turn signals in the BACK????? Never noticed that.......
Change the oil? I thought it ran ln gas!
Old 02-08-2019, 01:37 PM
shaunboutila's Avatar
shaunboutila
shaunboutila is offline
all joiking aside here xD but i ran the codes and seems like im getting p0340 witch would be cam and i just replaced it could be faulty but im also getting a crank code aswell Error Code P1391 is defined as CMP or CKP Signal Intermittent Condition. so im taking a guess and replacing both the crank sensors -_-
Old 02-08-2019, 01:38 PM
shaunboutila
and actually guys gotta make sure you drain all your break fluid and put anti freeze in it were suppose to get a flash frezze wouldnt wanna see anyhting happen to those trucks
Old 02-08-2019, 04:01 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,191 Likes on 2,944 Posts
Brake fluid? Erm..... I have never even seen anti-freeze for brake fluid......
Old 02-09-2019, 03:43 PM
shaunboutila
Default New code p0320
After changing both those the crank and the cam both new getting a new code 0320 any ideas before I burn it
Old 02-09-2019, 08:48 PM
HeyYou is offline
What brand sensors did you install?
Old 02-10-2019, 07:59 AM
shaunboutila
Not sure what brand they were there from car quest but I’m not getting a crank code or can code just interrupted signal any ideas if you have to reset the computer or anything ?
Old 02-10-2019, 09:01 AM
HeyYou is offline
These trucks don't really like aftermarket sensors in critical locations..... they just don't work as well.
Old 02-10-2019, 09:07 AM
shaunboutila
I get it , but it’s getting a intermixed loss of connection I wiggled the wires at at the crank fixed a broken ground and still nothing
Old 02-10-2019, 09:11 AM
HeyYou is offline
Basically what that means is, the PCM is not seeing the signal it thinks it should from the sensors. A typical symptom for a failing/cheap sensor.
Quick Reply: need help asap, 4.7 wont go over 3000 rpm
