Volt gauge reads voltage for a minute then disappears
Old Feb 12, 2019 | 08:24 AM
Superdrag73's Avatar
Superdrag73
Default Volt gauge reads voltage for a minute then disappears
Driving in to work this morning my volt gauge dropped onto the bottom peg. It ran fine and the lights were a little dim but still good enough to not stop. The truck starts up and runs fine every time, but after about a minute of driving it drops to zero on the gauge again. I checked for bad connections and didn’t find any. Sounds like alternator to me. Ideas?
Old Feb 12, 2019 | 10:41 AM
Wait until the gauge drops to nothing, and put a meter on the battery. What's the voltage there?
Old Feb 12, 2019 | 01:13 PM
Superdrag73
I didn’t do that, but when it’s running if I disconnect the battery the engine dies. That tells me it’s the alternator. I could be wrong.
Old Feb 12, 2019 | 01:20 PM
That test worked on older systems, but, isn't a valid test on newer systems.
Old Feb 12, 2019 | 03:30 PM
Superdrag73
I was afraid of that but a new alternator seems to have fixed it. The thing that threw me was, I would expect the gauge to read 12 volts if the alt wasn’t charging, not on the bottom peg.
Old Feb 12, 2019 | 04:29 PM
Dodgevity's Avatar
Dodgevity
Mine did the same thing when it failed...zeroed out. It didn't fail completely either.. it was intermittently working/not.
Alternator failure
