Engine swap or rebuild?
Old Feb 11, 2019 | 12:16 PM
Speedy03Dak's Avatar
Speedy03Dak
Default Engine swap or rebuild?
I have to make a decision pretty soon work my Dakota. Rebuild my 4.7, replace it or do an engine swap. There's no piston or block damage so the rebuild would be fairly inexpensive, for a 4.7l anyway, and a new (Remanufactured) long block 4.7l is about $2800. I'm thinking also for the engine swap going to a 5.9l which I'm pretty sure isn't fuel injected so there wouldn't probably Jane to be ECU change and a transmission change. Any ideas are welcome. I've rebuilt the top end once before, that was about $1600 with labor and machine work.
Old Feb 12, 2019 | 12:05 AM
Vimes's Avatar
Vimes
What is your goal? What is your budget? Once you have determined these two things, your path will become clear.
Old Feb 12, 2019 | 08:32 AM
Dodgevity's Avatar
Dodgevity
What is the problem with the engine?
Old Feb 12, 2019 | 10:40 AM
5.9 is indeed fuel injected, but, that is not a trivial swap. Doing a hemi swap would actually be easier.......
Old Feb 12, 2019 | 03:33 PM
Speedy03Dak
No real problem exists, just has 310k miles on it and the truck needs to be repainted. Wanting to restore her to her former glory!
Old Feb 12, 2019 | 03:34 PM
Speedy03Dak
I never really considered the 5.7l option since it didn't come in the Dakota. Would I need to change the transmission?
Old Feb 12, 2019 | 04:45 PM
I *think* it will bolt right up.......
Old Feb 12, 2019 | 04:55 PM
Dodgevity's Avatar
Dodgevity
Pssshhhh.... I got 299K and it feels like the engine is just getting broken in. These things can go for eternity if you keep oil and coolant in it.
