3.9 to 5.9 swap compatibility
I’m about to buy a 98 ram 1500 with a 5.9 to use to swap out my 3.9 from my 03 dakota. Will this work? I understand i’d have to switch the oil pan but other than that just the wiring harness and pcm will all be fine to use in the dakoter? thanks
Need to add the wires for the two additional injectors, and flash the pcm so it knows it has a v-8. May have to extend parts of the wiring harness to reach where they need to be. also need to make sure you have the correct flex plate for the 360. Aside from that, pretty straightforward swap.
Moving this to second gen Dakota section.
