3.9-5.9 engine swap flywheel
Old May 20, 2019 | 03:47 PM
Aaron H's Avatar
Aaron H
Default 3.9-5.9 engine swap flywheel
Will a 98 ram 2wd 1500 5.9 flywheel work in my 03 4wd v6 trans? the ram is the truck i pulled the 5.9 out of now the 5.9 is rebuilt and ready to go in
Old May 20, 2019 | 04:23 PM
93 ragtop's Avatar
93 ragtop
If you have the NV3500 5 speed, I believe it will, but hopefully others will step in.
Old May 20, 2019 | 05:28 PM
Yep, should work just fine.
Old May 20, 2019 | 08:36 PM
Aaron H's Avatar
Aaron H
Alright man thank you
Old May 22, 2019 | 03:12 PM
00t444e's Avatar
00t444e
I wasn't aware that they made a 1500 5.9 with the 5 speed. Did it have the nv3500 or nv4500?
Old May 22, 2019 | 03:18 PM
They didn't. If it had a 5 speed, it was a 5.2. Someone may have changed to the larger motor later. The heavier duty trucks got the 5.9 and a 5 speed though, but, that was the NV4500. NV3500 never came behind a 5.9 in anything from the factory.
Old May 22, 2019 | 03:19 PM
Aaron H's Avatar
Aaron H
both of the trucks are automatic. pretty sure ram is 46re and the 3.9 dakota is 42re
Old May 22, 2019 | 05:02 PM
00t444e's Avatar
00t444e
The autos have flexplates and yes I believe they will swap you may have to use the torque converter also, but I would recommend getting a better aftermarket one with a higher stall speed.
Old May 22, 2019 | 05:46 PM
Aaron H's Avatar
Aaron H
Can you recommend a good brand for an aftermarket flex plate/ flywheel?
Old May 22, 2019 | 05:50 PM
00t444e's Avatar
00t444e
A stock flexplate is fine, for the torque converter Hughes and TCI are both good brands that have been around for a long time.
