No bus!!
Old Aug 24, 2019 | 03:03 PM
Mike Wayne's Avatar
Mike Wayne
Default No bus!!
Ok so i have read almost all threads on this issue and been troubleshooting problems. My truck is a 02 4.7 qc 4x4 auto. I am showin the no bus code but no other codes, the truck has been running perfect for 2000 mi since i got it. Its got around 163k on it and its been dying on me and as long as i leave it set over night it starts and drives but only for about 10 min. It is only showing the no bus code nothing else.
Old Aug 24, 2019 | 04:45 PM
magnethead's Avatar
magnethead
So it only errors out after about 10 minutes of driving? Does the engine die when this occurs?
If so, this tells me it is due to heat.
There is a screw you can remove that relieves some stress pressure on the PCM circuit board.
Once it dies, you can also have a friend toggle the key while you check for 5 volts at a throttle body sensor.
Old Aug 24, 2019 | 10:21 PM
Mike Wayne's Avatar
Mike Wayne
Yea it dies out and takes awhile to start again. The last time i checked no other codes were showing but when i turn the key on the check engine light is on but goes away once i start it
Old Aug 24, 2019 | 10:57 PM
Mike Wayne's Avatar
Mike Wayne
What screw on the pcm are you talking about? I am leaning on a new pcm but before i get one i just wanted to see if its something else. As far as doin the whole ignition set up and battery deal i can see that would be a issue but it was fine before. I did notice that whoever had the truck before me has messed with the wiring under the dash. The pcm looks to be the original one and a couple guys said they changed it and no problems after that
Old Aug 24, 2019 | 10:59 PM
Mike Wayne's Avatar
Mike Wayne
I have noticed that it idles a little lower now around 700 or so but no other problems
Old Aug 25, 2019 | 12:09 AM
Mike Wayne's Avatar
Mike Wayne
Well i did the check and the odometer wasnt showing any codes but the check eng light was on and blinkin. So i reset the pcm and it started right up. I dont have a code reader on me but last time i did it no codes were shown.
Old Aug 25, 2019 | 12:11 AM
Mike Wayne's Avatar
Mike Wayne
I just changed the oil about 1k miles ago but never the less she does burn oil and its not a head gasket or oil seal
Old Aug 25, 2019 | 12:13 AM
Mike Wayne's Avatar
Mike Wayne
Im always checkin the oil and the pressure has never been low but it does get hot and the gauge shows normal temps. So what you are sayin about over charging could very well be my problem.
Old Aug 25, 2019 | 12:22 AM
Mike Wayne's Avatar
Mike Wayne
Im gonna take it down to my garage and mess with it some more tommorow. I appreciate all your help bud this is one of them problems that will spin the hell out of you and from what you have done is most likley gonna be the fix so thanks
Old Aug 25, 2019 | 12:25 AM
Mike Wayne's Avatar
Mike Wayne
Yea i just did the front main seal like 1k miles ago but i didnt do any other ones but thats what is likley the prob. This is my second dakota and my first 4.7 but they are all the same foreal!lol.
