Finally: an LED compatible Combination Flasher
#21
#22
I don't have a Ram FSM handy but I think they use the more common relay-looking flasher. I don't think the flashers were controlled by the Body Control Module/Central Timer Module until the model change in 09 (which is when the "Bulb out" VHIC message came around)
#24
#25
#27
I've ran short on combination flashers to modify here. I found what was left of my resistor stash yesterday but I haven't found any cores. Good reminder that I need to find a good day off from work to go junkyarding for hard to find parts for these trucks.
#28
Glad to see some pertinent info on this subject. Thanks for the wisdom, even 5 years later, that's awesome. Better you think to mod the original or an aftermarket module or no difference? Could you link the resistor you found, also what wire did you use? I have 24g tinned copper wire I use for power tool battery packs, should I invest in better stuff?
#29
https://www.mouser.com/ProductDetail...cgytHlPQ%3D%3D
https://www.mouser.com/ProductDetail...gNqraIQQ%3D%3D
I believe the second one is the one shown in the original photos. But both are 1/10 of an ohm (100 Milliohms) and will work for the application. The first one is just a bit smaller.
24 will be too small for a safety margin. I used 18. Have to keep in mind that worst case, 3 incandescent bulbs per side with flashers on will pass 9 amps through the wire and resistor. LED's as intended will be much less, but you always have to think worst case.
