Cat delete
Old Jan 2, 2020 | 04:15 PM
Teckus's Avatar
Teckus
Default Cat delete
I recently got a code p0420, I know it isnt bad or anything expect it made me want to cut off the cat anyways, it atleast gut it. Is there anything I should be aware of or an easier way of getting it without taking off? It is a 2002 dakota slt quad cab
Old Jan 2, 2020 | 05:43 PM
volaredon's Avatar
volaredon
My 01 wouldn't let me, I tried, so an 02 won't let you either unless you want a constant chronic check engine light.
i had an injector(s) stick wide open on me, within 6 miles of putting a brand new cat onto it, made the whole exhaust glow cherry red and melted down said brand new cat. So once I figured out what was going on, I stuck a pipe in the exhaust in place of the cat.i wasn't about to waste the money on another until I was sure I had the problem solved. It also took out a freshly rebuilt engine with the same 6 miles on it. Washed out the cylinders/ rings/bearings.
So I was determined to run catless until I was completely sure that it wouldn't happen again. But once that Damn CEL appeared with the PO420 I had to put another cat onto my rig, because I wasn't about to stare at that orange light all the time.
On some of the older ones you could get by with it.
But then again if you live in an emissions test area they won't pass you without a cat even if you blow good numbers out of the tailpipe.
Old Jan 2, 2020 | 05:47 PM
Teckus's Avatar
Teckus
Even if I gutted the cat it would have problems? I cant imagine everything like that going wrong because of 1 little thing, I already have it fully straight piped expect of the cats, I have dual exhaust setup with cherry bombs but wanted it a little louder. I was thinking cut a thing on the side and dump out the insides
Old Jan 2, 2020 | 05:51 PM
If you have inspections, you will fail. Your truck will stink and sound terrible straight piped.
Old Jan 2, 2020 | 05:54 PM
Teckus's Avatar
Teckus
a v8 sounding terrible? Is there videos of fully straight piped 5.9l v8 that you've found? fill look again, I also do not have inspections in my state.
Old Jan 2, 2020 | 05:55 PM
primem's Avatar
primem
the cheater fix is spark plug anti-fowlers but you didn't hear it from me...Illegal!!
Old Jan 2, 2020 | 06:13 PM
rebeltaz83's Avatar
rebeltaz83
So is gutting a cat. Or just simply eliminating it.
Old Jan 2, 2020 | 07:27 PM
ol' grouch's Avatar
ol' grouch
I've used anti-foul adapters over the years and I've never heard of them being illegal. Removing or gutting the converter though is a Federal Offense.
Old Jan 2, 2020 | 07:28 PM
00t444e's Avatar
00t444e
Gut or remove the cat then pull the rear o2 sensor out and zip tie it to the frame. The only thing the rear sensor does is monitor the cat, by taking a reading and comparing it to the o2 sensor before the cat, as long as its reading lower you won't get a code.
Old Jan 3, 2020 | 12:42 AM
Teckus's Avatar
Teckus
I know this sounds kinda janky but I dont have access to a welder and I live in a small town but what if I cut out the side of the cat then used the big exhaust clamps to shut it back off again? Or is this gonna not work and I'll have to buy a welder?
