Rattling in engine area
Old Jan 30, 2020 | 08:21 PM
MoparMan1995's Avatar
MoparMan1995
Default Rattling in engine area
Hi all,
I have a rattling in the engine area of my 2004 Dodge Dakota4.7L 4x4 truck. It sounds like a rattle of a can of spray paint. It does it more and louder under load like when going up a hill and stops when I let off the throttle. Is it possible it could be the PCV valve? Where is that valve located? What else could it be?
Thanks in advance! You guys rock.
Old Jan 30, 2020 | 09:34 PM
magnethead's Avatar
magnethead
has power output been reduced?
Old Jan 30, 2020 | 10:59 PM
MoparMan1995
Not from that issue. It has a separate issue on cylinder 7 which i have a new coil on order to fix. But before the engine light/cylinder 7 issue I did not notice any horse power loss.
Old Jan 30, 2020 | 11:42 PM
magnethead's Avatar
magnethead
How do you know you have an ignition issue on 7?
I'm wondering if you've had a rocker arm or 2 fall off. The 4.7 is bad about that, because nothing actually holds the rockers in place - they just kinda float between the cam and valves.
Option B would be a loose flexplate.
Old Jan 31, 2020 | 09:22 AM
MoparMan1995
A code scanner told me about the cylinder 7 misfire.
Old Jan 31, 2020 | 12:50 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by MoparMan1995
Hi all,
Doubt if you'd be hearing a little PCV valve that loud. Maybe if you were under the hood but not while driving, I don't think. Sure it's not pinging off some bad gas or something physically loose, like the manifold, a heat shield or a loose spark plug?
Old Jan 31, 2020 | 07:06 PM
MoparMan1995
That would be a hell of a ping off gas. I'll look into it though and those other things. Thanks guys.
Old Jan 31, 2020 | 08:40 PM
magnethead's Avatar
magnethead
So you just ordered a new coil without investigating?
Oh, I hope it's the intake rocker that fell off. If you've been driving it this far with an exhaust rocker off, I hope you know a leprechaun.
Old Jan 31, 2020 | 10:36 PM
MoparMan1995
A mechanic told me to just order a cheap priced replacement coil off ebay and try that. I got a new one for $11. I plan on replacing the plug too.
Old Jan 31, 2020 | 11:32 PM
magnethead's Avatar
magnethead
<insert red foreman facepalm gif>
