2000 Dodge Dakota heater not working!
I have a 2000 Dodge Dakota 3.9 v6 base pickup.
I get no blowing fan but in running a hot wire from battery to fan, I have a blowing fan. I replaced the blower motor resistor "pack" (in added picture), and replaced the climate controls (from a junk yard). On turn on the controls, after turning the switches a few times, I hear a squee-ing noise (it does not seem to come from the fan) but the fan does not blow. When the truck is running and has heated up some, I feel heat from the defroster ducts but no real air blowing. I have approx 11.8v power to the speed selection switch, checked it with a circuit tester.
I replaced the 40 Amp blower motor relay with a new one. Checked the fuse for "Rear defroster/FRT Blower" and it seems good (used a continuity meter).
The picture below is the old blower motor "resistor pack".
This is the old one i took out snd replaced with a new one.
The picture below is the new blower motor "resistor pack".
Last edited by Qball2yall; 02-01-2020 at 05:03 PM. Reason: Need to add details left out
Wiring Diagrams: (For 2001: Your 2000 may differ)
https://photos.app.goo.gl/uCSN75s63sWMQ7VB7
https://photos.app.goo.gl/k1iVumseYkkNr9UYA
Forgot to add some information
I have power to the controls, power to the blower relay pack and power to the fan, so I am confused as to why I do not have a working heater? I tried to find out where that squee-ing noise was coming from, it seems to orinate somewhere in the middle of the dash?
With the speed controller set to 'high' speed:
1- Measure the voltage at the 12 gauge Dark Green wire supplying power to the blower motor, and note it.
2- Measure the voltage at the 12 gauge Dark Blue / Yellow wire coming out of the blower motor, and note it.
3- Measure the voltage at the 12 gauge Dark Blue / Yellow wire going into the resistor pack, and note it. (This Should be the same as step 2)
4- Measure the voltage at the 12 gauge Black / Tan wire coming out of the resistor pack, and note it.
5- Measure the voltage at the 12 gauge Black / Tan wire going into the control panel, and note it. (This Should be the same as step 4)
6- Measure the voltage at the 10 gauge Black wire coming out of the control panel, and note it.
Please make sure you use a known-good ground reference for the volt-meter at every stage.
Report back your findings and I'll explain what's wrong.
Many resistor kits supply larger wiring to it since it's a known problem with the smaller wiring to the resistor[many burnouts].Its a good idea to replace that wiring when new harness is replaced .
High fan setting can bypasses resistor.
.On mine ,an common,it burnt out - pic
Trending Topics
