Which Headlight To Use??
Old Feb 1, 2020 | 10:52 PM
FredT's Avatar
FredT
Default Which Headlight To Use??
Looking for some solid information on replacement headlamps. I feel that I need some new headlamps that are maybe 30% - 50% brighter than the ones I have now in my old 2004 Dakota. Everything I see suggests to me that the original headlamps were probably around 1000 lumens. (I keep running into that "9007" designation everywhere)... I do not wish to spend $1000 on a high energy system as my intent is NOT to blind oncoming drivers. I'm thinking that maybe some new halogens at about 1500 lumens would be the ticket - as opposed to HEDs or LEDs. What do you think? Anybody here have tons of experience with this type of thing? Please accept my "THANKS" in advance... FredT
Old Feb 2, 2020 | 07:50 PM
wheily's Avatar
wheily
i ordered some bulbs i think they were hella brand yellow coated .they worked grate had a yellow ish light on low beam and bright blue on high beams
Old Feb 3, 2020 | 06:12 AM
ol' grouch's Avatar
ol' grouch
9007 is your bulb size. I've had good luck with Sylvania Silverstar bulbs through the years.
Old Feb 3, 2020 | 08:56 AM
Dodgevity's Avatar
Dodgevity
I got these headlights some years back. I've modified them a bit since then. All the bulbs are LED, including the headlight low/high beam. The LEDheadlight bulbs are supposedly 12,000 lumens, which sounds like a really high number. (They are no longer available on Amazon, but there are others that are similar.) They are bright, but not ridiculously so. The important thing is, aiming your headlights properly so they don't blind oncoming drivers. When I pull up behind a vehicle, the beam cutoff does not rise above the top of the their rear bumper and when driving behind one, it usually cuts off about halfway up their trunk lid. I've never once been flashed since using them and I had my wife drive the truck while I was in another car checking out the lights. No issues
Here are some LED bulbs that should work for you:
https://www.amazon.com/gp/product/B07KBGX6SN/ref=ox_sc_saved_title_5?smid=A126Q4T86JLNL&psc=1 https://www.amazon.com/gp/product/B07KBGX6SN/ref=ox_sc_saved_title_5?smid=A126Q4T86JLNL&psc=1
Old Feb 5, 2020 | 11:38 PM
FredT's Avatar
FredT
Thanks for the replies folks. I had almost settled on halogen bulbs after conferring with several others... but maybe LED is the way to go. Also, I had spotted (don't remember where) some bulbs that were rated at about 1700 lumens, and I am about the pull the trigger on those. In addition to all that - like so many others - I need to either "rework" my headlight assemblies or get new ones. That "UV" is really detrimental to acrylic - as you all know. Again -> "THANKS" for your replies.... FredT
Old Feb 6, 2020 | 09:32 AM
AM-Autoparts.com sells a variety of headlight housings, including stock replacements. Their prices are good, shipping isn't outrageous, and they are of reasonable quality. I put a set in my 96 Ram when I bought it, and they still look brand new 7 years later, when I sold it. I like them so much, I bought a set for my 98 when I got it. I also installed the LMC Truck 'heavy duty headlight harness'. Uses relays to power the headlights, and the headlight switch only controls the relays. So, much less load on the switch, and better power feed for the headlights. Combine with some good Bulbs (I used the sylvania silver stars) and you get really good light output.
Old Feb 6, 2020 | 09:18 PM
Dodgevity's Avatar
Dodgevity
In my earlier post, I typed 1200 lumens, when I really meant 12,000... 6,000 per bulb! If you go LED, go with high lumens. The white light given off by LED lamps is not as effective for human vision as the yellow light from regular old halogens. Better pic
Old Feb 9, 2020 | 04:22 AM
Vimes's Avatar
Vimes
On the housings, I've had excellent luck with plain old rubbing compound like you use on car paint. I use it on my work car's headlights about once every 6 months, and they look nearly brand new. Takes 5 minutes. Be worth a try, and if you want you can still buy new housings.
Old Feb 9, 2020 | 10:25 AM
ol' grouch's Avatar
ol' grouch
AS a last gasp effort, you can also use toothpaste and a scotch-brite pad.
Old Feb 26, 2020 | 04:00 PM
YoungsModulus's Avatar
YoungsModulus
Silverstar is hot garbage.
