What did you do to your Dakota today?
I see this type of thread on other car forums I am on. They are used to provide forum members with upgrades/improvements/maintenance repair tips/etc.
Today, I replaced the throttle position sensor and idle air control valve on my '99 5.2. I was having rpm surges at highway speeds; 1800 to 2200.
The old tps looked good, but the iac was fouled up with carbon deposits.
I probably could have soaked it in gasoline and cleaned it off, but for $40 and these probably being the original parts, I just swapped them out.
Truck runs much better now.
Been dealing with a coolant leak for months, losing around a few cups every few weeks. Finally rented a pressure tester today. Rental was $162 at O'Reilly's and it was refunded when I returned it an hour later.
It took me roughly five minutes to find the leak. You can see it in the pic. One of the worm clamps on the heater hose was loose. If you look closely you can see the green drop of coolant falling. Tightened the clamp for now and it stopped, but I'm going to replace the hose and use a spring clamp soon. Worm clamps suck!
