Booster or master?
No ,I hear the spring sound at the front around booster an cylinder as I pump an especially RELEASE the pedal.Its a new sound .
An I did bleed them in that order 2 times all the way around .
I'm leaning toward the master but I'm gonna get another person to put their hand on the booster an listen closely for the new noises an any changes.
I didnt get a colapse in the fluid cap in the past when it all was workingworkin.Also on the front left bleed is when it collapsed again [no driving just pumping to bleed].
I meant when driving it had been collapsing often.
I put another booster on it an no more squeek or hum noise.!.
Theres still air in the system though but a tad tighter on the pedal.
I guess I'll have to get the scan tool.
to bleed the abs ..
Should I look at testing/replacing the master ?
to bleed the abs ..
The following users liked this post:
Vimes (04-24-2020)
A follow up.
It was BOTH . But significant difference after new master cylinder! Great pressure since bleeding an changing fluid, no air.
And NO .I never had to take it to a dealer for a abs modulator bleed down.
From what I've read an by my experience on mine the 2WD -not 4WD -doesnt have to be DRB dealer bled .
4wd may require it .
Thanks
Thanks
A follow up.
Thanks
Thanks
