Flasher relay
Old May 22, 2020 | 08:05 PM
akeED's Avatar
akeED
Default Flasher relay
My turn signals and flashers, along with my brake lights went out. I replaced the relay and still no flashers signals or brake lights.
HELP
Old May 22, 2020 | 08:33 PM
Check fuses?
Old May 27, 2020 | 04:18 PM
akeED's Avatar
akeED
Replaced 2 fuzes and got everything back except front right signals and flashers
As well as the right signal indicator on the dash
Old May 27, 2020 | 08:59 PM
magnethead's Avatar
magnethead
brake lights are a simple in-and-out on the combination flasher. There are no relays or anything in the path.
Almost sounds to me like you have a short on the right rear section of wiring, faulting out the onboard chip. The CF receives power from the brake pedal switch.
To test it out of the truck, place the combination flasher with terminals facing you, and the side with the four "mini terminals" towards the top.
On the right side, apply 12 volts to the middle-top vertical blade between the mini-blades (brake light in). Attach your test light or multimeter to ground, and place the positive probe against the "middle right" horizontal blade, which is right rear output, and the "bottom left" horizontal blade, which is left rear.
Old May 27, 2020 | 10:07 PM
akeED's Avatar
akeED
Thank you very much for the information.
Old May 28, 2020 | 12:25 AM
magnethead's Avatar
magnethead
Keep in mind this is looking at the socket. You'll want ti mirror it to work with the CF.
Pin A5 "ground" is not populated on the factory harness; there is no direct ground to the CF. It grounds through the lamps and the turn/hazard switch.
https://photos.app.goo.gl/EqVVKBTike37LkGC8
Old May 31, 2020 | 12:43 AM
akeED's Avatar
akeED
It's fixed.
Thank you for all your help I truly appreciate it.
Old May 31, 2020 | 03:04 PM
magnethead's Avatar
magnethead
what did it end up being?
Old Jun 4, 2020 | 11:46 PM
akeED's Avatar
akeED
The flasher relay, 2 fuzes and a couple wire connecters.
