Orifice tube stuck in line
Now you know. A year from now, someone will have the same problem and you can tell them the solution.
The following users liked this post:
73scamp (06-25-2020)
How funny the orifice tube yes can be had for $26 but the small plastic valve cost $1 or less at your local auto parts store.
To get it out use air pressure or if you have good water pressure on your house water line that has worked for me.
I've replaced my valve two times
and yes they are made to be replaced the problem is they tend to get pushed up the line after a few years of use.
so either $26 or $1 a little work saves you $25
Now that I think on how I did it I used a high pressure water sprayer that thing blew out with a pop.
73scamp (07-04-2020)
