No bus, no start
Old Jul 8, 2020 | 06:47 PM
Aaron H's Avatar
Aaron H
Default No bus, no start
Recently replaced the 8 wire female end of the connector for the overdrive solenoid. Also soldered 1 wire i saw falling out from the previous splice on the neutral safety switch. After i was done i went to start my truck, it started and ran for a couple seconds then died out. Now, it will crank but no start. dash says no bus. I’m thinking i may have soldered a wrong wire? A diagram would help but i don’t have one
Old Jul 8, 2020 | 09:11 PM
magnethead's Avatar
magnethead
Truck details? Thinking you might have cooked the PCM with a crossed wire.
Old Jul 8, 2020 | 10:09 PM
Aaron H's Avatar
Aaron H
03 dakota 5.9 46re
Old Jul 8, 2020 | 10:59 PM
magnethead's Avatar
magnethead
  1. 16 Red = TC Relay Output
  2. 18 VT/WT = 5 Volt Supply
  3. 18 BK/LB = Sensor Ground
  4. 18 LG/RD = Gov Pres Sig
  5. 18 VT/WT = Gov Pres Sol Control
  6. 18 Brown = O/D Sol Control
  7. 18 OR/PK = TCC Sol Control
  8. 18 GY/BK = Trans Temp Sens Sig
Old Jul 9, 2020 | 12:19 AM
Aaron H's Avatar
Aaron H
In the instance i got pin 2 and pin 5 swapped, would that cause a no start. It’s possible that those two i could have mixed up
Old Jul 9, 2020 | 06:35 PM
magnethead's Avatar
magnethead
It shouldn't.
I just realized they are the same color. Either my book is wrong, or somebody screwed that up when they designed the harness....bad juju
Old Jul 10, 2020 | 10:32 AM
00DakDan's Avatar
00DakDan
Section Moderator
My book has the same thing with the colors.
Check the 5v supply on pin 2. See if it is working.
Old Jul 10, 2020 | 02:50 PM
Aaron H's Avatar
Aaron H
Hey guys pretty sure i got the wires backwards. i unplugged the connector then swapped the ecm with a spare one i had laying around. It started right up and didn’t say no bus. I am positive i’ve fried my pcm by getting the violet and white wires mixed up. I’m going to double check and make sure i get it right this next time. Lol fml
