01 4.7 Lopes at idle
Old Aug 22, 2020 | 01:35 PM
rugger2's Avatar
rugger2
Default 01 4.7 Lopes at idle
My 2001 4.7 with the 5sp 'lopes' at idle sometimes. By lopes, I mean the idle speed increases and decreases from 500 to 1100 RPM. Not always, and it usually is occurring when the engine is fully warm and the AC is operating. No codes and other wise runs great.
Old Aug 30, 2020 | 10:24 AM
Dodgevity's Avatar
Dodgevity
IAC valve or TPS. Replace only with mopar. Check plugs too.
Old Sep 1, 2020 | 01:42 PM
00DakDan's Avatar
00DakDan
Section Moderator
In addition to the above, when did you last clean the throttle body - as in remove it to clean it?
Mine occasionally does the same thing, 4.7 5 speed.
Old Sep 1, 2020 | 06:43 PM
rugger2's Avatar
rugger2
The throttle body has never been cleaned nor removed.
Old Sep 4, 2020 | 10:15 AM
00DakDan's Avatar
00DakDan
Section Moderator
It wouldn't hurt to clean it out then. You'll be surprised at the amount of crud that collects.
Old Dec 15, 2020 | 08:47 PM
Redlineenvy's Avatar
Redlineenvy
I have just purchased a 2005 Dakota 4.7L. This idle surge from 500-1200 rpm is the very first problem. (only had it a week). I have been searching and this seems to be the answer.
Old Dec 16, 2020 | 09:51 AM
Vacuum leak?
Old Dec 16, 2020 | 06:35 PM
Redlineenvy
Vacuum leak?
No the throttle body cleaning and the TPS.
Its always good to check vac lines.
