Incandescent to LED conversion for your HVAC controller!
So if you don't know how to remove your HVAC controller, you shouldn't be doing this mod.
Tools needed:
Once you have the controller out, pull the ***** off and pry open the controller back.
This is what the controller looks like opened up.
Check the bulbs fitment in the light track. They should fit the cup perfectly. Red dot is the positive terminal on the bulb.
The most frustrating part of this mod is getting the bulb between the face and the board. With the new bulbs being LED, they'll be polarity sensitive. Positive is towards the center of board, negative is towards the outside of the board. Once they're oriented and the board is in the face, press the ***** back on to hold the board onto the face for soldering. Bend the wires over the contacts and solder contacts to the board. It's best to solder the bulbs to the board this way to set the depth.
Make sure the wires aren't touching any other contacts.
What the board will look like after the bulbs are soldered to the board.
For testing afterwards, these are the terminals you'll need to apply power to test the lights. The positive terminal is the very bottom left.
This is what it looks like afterwards.
Happy modding! This mod works for all 2001+ Dakota's and Durango's, and Rams. This new controller was from a 2004 Ram 2500.
Tools needed:
- Screw driver
- Pliers
- Soldering iron and solder
- HVAC controller
- Sylvania 168 LED bulbs
Trending Topics
I found direct fit LED replacements on Amazon.
Search for "T5 NEO wedge" and you'll find numerous sources for them.
The ones I purchased came in a package of six for under $6. https://www.amazon.com/gp/product/B00S92Q93S/
I just installed them, and they work great. Nice, even illumination.
