Fuel pump finally dying @ 320K?
World Parts
I was a little surprised to see you comment regarding airtex pumps, I have used them for years and have had great luck with them.
There is a company called World Parts. They sell OEM GM and Dodge reboxed parts at crazy ridiculous prices.
Genuine GM and Mopar Parts Delivered Directly To You | World Parts Direct
Thanks for the link, I'll check it out.
I have quite a bit of direct experience with Airtex pumps....... from back when I was doing the wrench-turning thing for a living. They were universally horrible. They were inexpensive, so, we gave them a shot. 99% of them failed within six months. Some failed within days, still others were bad right out of the box. ALL of them failed within a year. (still under warranty.....) We stopped using them, and when questioned by our customers WHY we would only install the 'expensive' pumps, asked them how often they wanted to be stranded.
Their reputation has not improved any in the intervening years. They still suck.
I really wanted to go with Denso, but turns out they don't make a pump for the 24 gal tank, as least not that I was able to find. It seems the Delphi pumps are being made in China now. Not sure if that has affected quality, but you know how the story usually goes.
I don't think I've ever tried to test fuel pressure with an oil pressure gauge. I'm not sure it would read correctly. I have two sets of refrigerant gauge sets for a/c systems. The R-12 gauges won't work with R-134 and vice versa. The substances have different specific gravities. Plus the gasoline will be a lot thinner and and acts as a solvent. It may ruin the gauge. As for being in the vehicle, I've always unhooked the original gauge and installed an outside gauge at the oil port.
If it's a rental tool, I'd take it back and get a fuel pressure gauge kit. They have a lot of adapters for different fuel systems. I didn't have the needed adapter for my '93 GMC so I rented a kit at O'Reilly's. I used the adapter, took the set back and bought the adapter from Summit.
As far as far as installing gauges... I don't know what you mean by installing an outside gauge (that's what I consider a test gauge... install it, get the reading, disconnect and put it away). Do you route it into the interior? If so, I would only go with gauges that read off a sender. I would not route any flammable liquid into the cabin, which oil is, let alone gasoline... maybe I'm misunderstanding you?
I do plan on renting the gauge. I own the set pictured. It's a cheap Harbor freight job. If it had the adapter, I would use it. Gas and oil are both liquids and should exert the same type of hydraulic pressure. Refrigerant is gas and oil mix, as far as I know, so different type of pressure.
Install, read and unhook is what I meant. As for in cab installation, I prefer electric gauges just because they are easier to install and use. More accurate most of the time. I remember the old fluid pressure gauges. Look at a truck or car from the 1950's or earlier. Trying to remove one without breaking the tube is a challenge.
