Speedometer off
Old Mar 19, 2021 | 11:20 PM
Slick 50's Avatar
Slick 50
Default Speedometer off
99 SLT 4x4 5.2L
Is there a way to correct the speedometer reading if you have larger tires than the original build?
Is there a different output speed gear for the speedo cable?
Currently have 31x10.5 R15 installed, which matches my VIN print out, but the door pillar sticker says P215/75R15.
I used a tire conversion chart online and it confirmed that the difference I see on my dash is because I have the 31's installed.
Old Mar 20, 2021 | 08:59 AM
00DakDan's Avatar
00DakDan
Section Moderator
There is no speedometer cable. The speedometer is electronic. It's read from the speed sensors.
A DRBIII, old dealer item, can update the computer.
Old Mar 20, 2021 | 09:10 AM
Most of the big chain tire stores should have the ability as well.
Old Mar 21, 2021 | 04:14 PM
Slick 50's Avatar
Slick 50
Thanks guys I will ask around.
