3.9l stalling please help
So this truck is a 97 slt 3.9L
Brought the truck and drove it 21 miles home
No problem
The very next day the truck stalled at random
Call car guy to do tune up but paid to find out heads were cracked.
Replaced ecm, engine, radiator and heater core
Drove fine for 2 days
Then left my lights on battery died
Replaced battery and stalled when going into reverse
No check engine light
Idle sputters sometime
When driving idles to 3 aggressively then settles down
tow truck came to pick up my truck to take to shop and noticed the gear selecter O/D Wires snapped at lever
He said while driving it on to the bed that torque converter feels like its locking up
Could these wire cause my truck to go into auto shut down
Please help
No problem
Please help
No. Those wires just move the funny little indicator that tells you what gear you are in.
How old are the O2 sensors? Does it start ok, then start running funny after a couple minutes? Or is it funny right away? How are the ignition parts? Did you replace them when you did the engine?
dies when coming to a stop or going into reverse and switching back to drive.
Ignition? I changed spark plugs
but nothing inside by dash.
also it sat for like 2 days b4 tow truck got here
and the driver couldn't get it to stall but said he could feel TC locking while driving it on the bed he said when he felt it lock up he notice rpm dropping as if its about to stall
Also when driving it before the problem came back after engine swap
the car feels sluggish when trying to get passed 40 then it feels like its shifting and takes off lol and then drops back to normal.
What plugs?
Might wanna clean the throttle body first. Disconnect the battery, pull it off, clean the snot out of it, especially the IAC well..... Put it back on. Hook up the battery. Turn ignition to "on", (not start) count to ten, THEN start the truck. Should figger out idle pretty quick, this method gives the PCM a chance to learn the zero values of various sensors. Might help.
When the engine was swapped, what did you do with the crank sensor? They are generally victims of engine/trans swaps......
Just got truck back from shop
he said he couldn't find anything wrong for 3 days it didn't stall him
said he couldnt find find a problem but the engine is good and the trans runs up hill like a champ.
other than a delay when you hit the throttle.
he said dnt worry about.
i know the problem is there im not crazy it dies when it feel like it. I didnt change crankshaft position but i have one new in my house
but would that cause a sluggish driving and why would my old and new engine both have a messed up crank sensor
Trending Topics
Crank sensors are frequent victims of engine/trans swaps. If it isn't removed prior to R&R, they are HIGHLY likely to be damaged during the process. And of course, they are in a TRULY fun spot to get to.......
but still hesitant to drive because i really think theres a problem. Took to autozone and mechanic still no codes
