6x6 dakota build
Old May 30, 2021 | 09:02 PM
Might be too long for the engine compartment...... But, it would certainly be a good choice, if you could make it fit.
Old May 31, 2021 | 04:11 PM
magnethead's Avatar
magnethead
So an FYI, I know how that dakota was done, and it's exactly as HeyYou described - it's a bolt-in gear-over using a Corp14 or F9 middle axle and stock rear axle. I know the person who did it, used to work for him (Daniel Little; formerly USA-6x6, last I knew was operating under DBL designs).
Using a set of rockwells with the 4.88 gear conversion would be one approach. I don't know if Daniel or his competitor offer the gear-over as a separate unit. Last i checked SCS was making them for the outfitters.
https://50states50weekends.wordpress.com/2014/10/22/jeeps/
https://gonzodave001.wordpress.com/2015/03/09/axles/
Old May 31, 2021 | 10:16 PM
Dakotaquad's Avatar
Dakotaquad
that is very nice also alot of choices again:P
Old Jun 3, 2021 | 04:11 PM
Dakotaquad's Avatar
Dakotaquad
starting to like the idea of the scs threw transfer case. Just wondering which axles/diffs should i use for the build should i stick to my stock 12 bolt 9.25 inch rear or getting something beefier ?
Old Jun 3, 2021 | 04:19 PM
Need an axle that it will actually bolt to. I think that leaves the ford 9 inch.....
Old Jun 3, 2021 | 04:25 PM
Dakotaquad's Avatar
Dakotaquad
so i have to find a set of 9 inch fords so i can make this? that does not sound to hard. :P
Old Jun 3, 2021 | 05:16 PM
Considering Ford has used them in just about anything, forever.... They should be pretty easy to find. Likely going to need some modification to fit properly under the dak though. I suspect any you find, will be too wide, need to move spring perches, and shock mounts and such as well.
Old Jun 3, 2021 | 05:48 PM
Dakotaquad's Avatar
Dakotaquad
yea probably right but i dont mind. now since i am doing this should i also solid axle swap the from and put in a better suspension ?
Old Jun 3, 2021 | 06:40 PM
Probably. I suspect once the rear setup is complete, the truck will sit rather low in the front. May need to do the SAS just to level it out.
Old Jun 3, 2021 | 09:06 PM
magnethead's Avatar
magnethead
The SCS box bolts in place of the daytona support bearing in an F9 or Corp14. The third axle can be stock. On that dak, I believe they used a F9 center with Chry 9.25 outers to accept the stock 03/04 rear discs with the stock 6x4.5 lug pattern. Ride height was not raised IIRC to clear the gearbox, but at full compression it was close to the bed floor. Rear suspension was a mirrored 5 link I believe (a design that Daniel came up with to allow the rear axles to "rear steer" together, once upon a time there existed an animated CAD drawing of how it worked).
