Fuel pump issues
Aug 21, 2021 | 10:29 PM
Fuel pump issues
Truck won't start unsure if it's a bad relay or the pump,how do I find out which, please can anybody help.
Aug 21, 2021 | 10:31 PM
Aug 21, 2021 | 10:46 PM
Fuel pump
2003 rt 5.9
Aug 21, 2021 | 11:57 PM
Swap the relay with another, such as AC compressor relay. Rent a fuel pressure tester kit from the parts store, which is free when you return it.
Aug 23, 2021 | 01:11 AM
Define wont start please. Does the truck crank? Or does it do nothing at all. If nothing I'd be checking battery and starter as well.
Aug 23, 2021 | 02:55 PM
Yes it cranks and power is going to relay but pump is not coming on and my guages don't work
Aug 23, 2021 | 04:56 PM
Do the gauges show anything with the key on? Volt gauge should show battery voltage at least.
Aug 24, 2021 | 07:58 PM
Fuel pump issues
No but the dummy lights come on and a no bus in od window
Aug 25, 2021 | 08:19 AM
You have a failed sensor somewhere. Check and see if you are getting spark.
Aug 25, 2021 | 09:10 AM
Quote:
Originally Posted by
Jamscor
Dodgevity
Try these things. They will answer your question.
