03 Dakota Cab Mounts
Very nice truck,
Got to remove as much rust as possible, with a steel brush on a grinder or something like it.
When cleaned and looking at bear metal you can investigate if there's real damage from the rust, but by the looks of it you should be okay.
Depends on conditions you drive the truck for wich paint or coating u are going to use, we have winters with snow and ice, so i usually put on something like a tar based undercoating, they used on ships.
You could also buy underbody coating products or a decent metal primer, if you wan't you could paint it
Thank you for the replies. I am in Ohio so we definitely get snow. I’m going to get in there with a small steel brush and do exactly what you said. Thanks for the tip on the tar based coating.
Very nice truck,
The following users liked this post:
V8Cowboy (01-10-2022)
