PLEASE HELP! power steering high pressure hose fittings?
Old Apr 6, 2022 | 09:55 PM
gx368's Avatar
gx368
Default PLEASE HELP! power steering high pressure hose fittings?
HI folks, I have a 2001 Dodge Dakota sport 4.7L RWD Has anyone had this problem before? Trying to replace my power steering high pressure hose, but every site I look at that will fit my truck the fitting on the end is different. My old hose has a swivel type fitting but all the new hoses out there are a flare type fitting. will this flare type work? I attached some pics below
my old fitting- tampered end
new flare type
Old Apr 6, 2022 | 10:51 PM
Might be just the difference between OEM, and aftermarket manufacturers. It's still just the o-ring that makes the seal. See how much they cost at your local parts store, and if they will price match...... (mine will, but, I have been going there for 30 plus years too.....) If it doesn't fit, much easier to return it.
Old Apr 7, 2022 | 12:43 AM
magnethead's Avatar
magnethead
All saginaw fittings have that outward flare. Yours is backwards and I can't for the life of me understand why. Yours almost looks like a 37* JIC flare, but JIC doesn't usually use an O-ring.
Old Apr 7, 2022 | 06:58 PM
gx368's Avatar
gx368
thank you for the response, I will try and let know if it worked. advance auto parts has it in stock near me.
Old Apr 7, 2022 | 07:15 PM
gx368's Avatar
gx368
Exactly, threw me for a loop too. I think they are just calling it swivel o-ring type l
Old Apr 12, 2022 | 10:16 PM
DionDell's Avatar
DionDell
Did you end up figuring it out?
I have the same problem and air is leaking in somewhere making it whine really bad and the flared end of the new hose I have doesn’t seem to fit into the pump I got because the pump seems to be more rounded and the o ring doesn’t make a seal.
I want to sell my truck so any tips would be great.
Old Apr 13, 2022 | 07:30 PM
gx368's Avatar
gx368
I will let you know still waiting for some parts...
Old Apr 25, 2022 | 07:37 PM
gx368's Avatar
gx368
installed new parts no leaks
pic of new pump and new style fitting
replaced pump, high pressure hose and return hose. new style hoses seem to be holding no leaks
