Torque specs
Old Apr 13, 2022 | 06:59 PM
hidden1's Avatar
hidden1
Default Torque specs
Whats the ft lbs on the bolt to dampener on 01 3.9 2wd?..Im getting different chart readings,
one says 135. An another 185 ..
thanks
Old Apr 13, 2022 | 07:44 PM
magnethead's Avatar
magnethead
The 3/4" main hub bolt?
180 ft-lb is the factory spec. Anything north of 150 should be okay.
USE ANTI-SIEZE OR THREAD LUBE.
The 3/4" bolt in the dragster is 250 ft-lb (highest the wrench goes) plus 1/8 of a turn
Old Apr 13, 2022 | 08:53 PM
hidden1's Avatar
hidden1
Vibration Damper/Hub To Crankshaft 135 Ft-Lbs 1620 In-Lbs 183.04 N-m Years: All
Note: Magnum - Vibration Damper to Crankshaft BoltVibration Damper/Hub To Crankshaft135Ft-Lbs1620In-Lbs183.04N-mYears:AllNote:Magnum - Vibration Damper to Crankshaft BoltType: BoltDim:Length:Head: HexagonGrade:
Saw this also ..yes its that bolt that goes thru balancer..
Pic is from that downloaded fsm
Type: Bolt Dim: Length: Head: Hexagon Grade
Old Apr 19, 2022 | 04:09 PM
hidden1's Avatar
hidden1
You are correct..
the other engines are 130 ft lbs but these 3.9 an similar are 180..
What technique do you use to prevent the balancer from turning when its already at 130?
Put some big bolts in the 2 large holes in balancer an a piece of steel to the engine?
Old Apr 19, 2022 | 07:16 PM
Bracing it against the cover probably isn't a good idea. It is aluminum after all. Put a couple bolts in, and use a bar thru the bolts to hold it in place. Or, do what I do, and just whack it in with an impact wrench, and call it a day.
Old Apr 20, 2022 | 08:38 PM
hidden1's Avatar
hidden1
Yep I could only get it to around 130 then i just used that earthquake/ impact on it a couple of times.
Not sure but if you were to guess would you say I gained another 20 or 30 ft lb ? I saw the socket turn another 1/2 inch as impact was on it .then it stopped .
thanks.
Old Apr 21, 2022 | 09:38 AM
Quite likely more than that. But, if it's tight enough not to come loose, but not so tight it breaks, it's all good.
