quick question about rear end sizes
Old Aug 19, 2022 | 01:10 PM
pampas56's Avatar
pampas56
Default quick question about rear end sizes
The rear end on my 99 Dakota 4x4 ran out of fluid and died. I intend to replace it with a used one from the nearby wrecking yard.
My BIL remembers hearing a rumor that the 2x rear end is narrower than the 4x. Can anyone confirm or refute this?
I know there is two different axles (8 1/4 and 9 something). Mine is the smaller one with 3.55 gears.
Is there any difference between a 2 and 4 wheel drive 8 1/4 rear end at all?
thanks
Steve
Old Aug 19, 2022 | 06:42 PM
I think the spring perches are in a different spot.... aside from that, I don't know. Best to find one out of a 4x4 though.
Old Aug 20, 2022 | 09:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
The frame dimensions are the same so can't see the rear end being wider. As Magnet says, the spring perches are different.
Old Aug 21, 2022 | 09:22 PM
magnethead's Avatar
magnethead
Heyyou actually gets that credit...but that's usually my line. haha. But yes I'm pretty sure I recall the leafs being outboard an extra half inch per side on dakotas. Plus the whole 4x2/4x4 perch location being 180 degrees out.
