Radio single dash line
Old Jan 22, 2023 | 07:44 PM
Kdma's Avatar
Kdma
Default Radio single dash line
Hey everyone, I have just replaced my front door speakers on my club cab Dakota. When I went to test them out my radio just displayed one single dash line, no clock no fm/am radio tuning. I can hear the speakers turn on but the head unit it self won’t do anything except display the single dash line. I have checked every single fuse under the hood and under the dash, all the interior lights and cluster lights work. None of the fuses were burnt. Wondering if anyone has any solutions or if this has happened to anyone before.
Old Jan 22, 2023 | 08:01 PM
What year is your truck?
Radio has two power sources, one for the memory, which is low amp draw, and another switched ignition feed, that actually powers the radio. Make sure you have both. Sounds like it is missing the switched ignition feed.
Old Jan 22, 2023 | 08:34 PM
Kdma's Avatar
Kdma
It’s a 2000, but would one of those powers have a fuse, I couldn’t find any burnt. But many it’s just a faulty fuse.
Old Jan 23, 2023 | 08:54 AM
Dodgevity's Avatar
Dodgevity
A blown fuse would give you no display at all. No line - no nothing. Try resetting everything. Pull the neg battery cable and turn the key to crank position, then replace cable.
Old Jan 23, 2023 | 09:31 PM
Kdma's Avatar
Kdma
So I did this whole procedure and ended up with the head unit not displaying anything anymore. Checked the fuses, nothing. All the interior lights work truck starts. But when I start the truck the speakers do a little pop. Louder than before. But I’m not sure what it could be. All in all head unit is giving me nothing.
Old Jan 25, 2023 | 07:51 AM
Dodgevity's Avatar
Dodgevity
You said you replaced the speakers. Did you pull the radio at any point? Did you run fresh speaker wires or use the existing wiring?
Old Jan 25, 2023 | 08:57 AM
Kdma's Avatar
Kdma
I didn’t pull the radio, and I used the existing speaker wires in the truck. I got no clue why it’s doing this.
Old Jan 25, 2023 | 10:20 AM
Do you have the infinity system?
Old Jan 25, 2023 | 12:04 PM
Kdma's Avatar
Kdma
No clue, how can I tell?
Old Jan 25, 2023 | 01:06 PM
I would think it would say on the head unit..... but, I've been wrong before.
Could try running your VIN here, see what it comes up with.
