Linkage
Old May 10, 2023 | 01:52 PM
Douglas McGinnis's Avatar
Douglas McGinnis
Default Linkage
While troubleshooting a wheel bearing issue, I noticed that my 4wd selector is not connected to my transfer case. There seems to be part of the linkage missing. Can someone tell me what that part name might be, and where I can find one? The piece missing connects from the bottom of my selector in the cab to the fork in the transfer case itself. It looks like it would be about 6" long with bolts on both ends.
Old May 10, 2023 | 02:59 PM
What are you driving? Year/model/engine/trans/t-case?
Old May 11, 2023 | 08:59 AM
Douglas McGinnis
Sorry. It's a 2000 with 3.9 v-6
Old May 11, 2023 | 09:20 AM
Douglas McGinnis
Edit: I'm not really a car guy, so all I can tell you is it's a Dakota, 3.9 V-6, 4wd (obviously). The front differential was replaced 6 mos ago or so. Hope this helps enough.
Old May 11, 2023 | 10:37 AM
Here is one for the 231 t-case.... Not sure if the 242 uses the same rod. 242 case has an All Wheel Drive setting. 231 does not.
Old May 12, 2023 | 09:51 AM
00DakDan's Avatar
00DakDan
Section Moderator
The rod is held in place with grommets. I found mine dangling once. You'll need to replace them as well.
I think the p/n is: 5017960AA. It may have been updated.
