Factory tach wiring
Old Dec 24, 2023 | 12:36 PM
Brukota's Avatar
Brukota
Yes, whenever I initially started the motor on the stock fuel injection, the tach worked fine. It only stopped working when i went carbureted
Old Dec 24, 2023 | 01:06 PM
Since all the other gauges work, the tach should as well..... did the sensor or wiring get damaged??
Old Dec 24, 2023 | 09:42 PM
Brukota's Avatar
Brukota
I don’t think so
Old Dec 25, 2023 | 09:51 AM
I would think that PCM would set a code if it wasn't getting a signal from the crank sensor. Have a scanner you can plug in, and see what the PCM thinks? Is the PCM seeing an RPM reading?
Old Dec 25, 2023 | 01:50 PM
Brukota's Avatar
Brukota
I will check when i get a chance
Old Dec 25, 2023 | 08:18 PM
magnethead's Avatar
magnethead
My guess is there should be multiple MIL for fuel injectors unplugged, as such the PCM may be going into safety shutdown and not sending a tach/cam sync signal.
