Clutch or master and slave?
Old Jan 29, 2024 | 03:53 PM
  #21
Originally Posted by Jgas94
No there is not a bleeder. That is why I had to pump the slave cylinder.
Bleeder on the slave would be pointless in any event, as it sits BELOW the master, and pushing air DOWN a line just doesn't work well.
Old Jan 29, 2024 | 05:33 PM
  #22
ol' grouch's Avatar
ol' grouch
Injection bleeding works that way. I never do it but I've seen it done. Similar to what the video shows.
Pushing the actuator rod in usually will force the air to rise in the line. It's possible the seals inside are weak. That's why pumping the pedal works, but not quite all the way. Like a brake master cylinder going out.
Old Jan 29, 2024 | 09:38 PM
  #23
98DAKAZ's Avatar
98DAKAZ
Smile 98 up
All Dakotas 98 and newer use a one piece master slave clutch system they can not be bleed.
Not expensive but a PITA to install.
Hello all been a long time
