Definitely remove the check valve in the trans cooler line. If you cut the tanks off the OE type radiator, you'l find it's just a 3/8 copper tube from one fitting to the other. It doesn't actually do much at all.
Wow, this radiator is worse than I could have imagined.
Brackets aren't even close
Fail on the lower fan shroud
Fail on the fan hole alignment
Fail on the evap hole alignment
The only thing that does line up is the upper shroud.
And when choosing a tranny cooler, I measured the OEM radiator and didn't take into account the thicker core. now there's not enough room between the condenser and the bumper to fit the cooler.
Should have listened, but nooo I have to try out chinese garbage that's twice the price.. lol.
Been there, bud. Notice that the 4.7 has no support for the filler neck. Pushing down on the rad cap eventually breaks the plastic, so go gentle after you fix it. Look up the Mopar part. The cheap plastic filler necks in the auto parts stores won't last long. Ask me how I know?
Good ole Chinese QC. Send it back and get the CSF.
